Software
Software related to the project, developped within the Alcovna/Colib’read projects, or not.
  • KisSplice – A local transcriptome assembler for SNPs, indels and AS events
  • Mapsembler2 – targeted assembly and visualization
  • discoSnp++ – discovering Single Nucleotide Polymorphism (SNP) from raw set(s) of reads
  • TakeABreak – inversion breakpoints detection directly from raw NGS reads
  • Lordec – hybrid error correction program for long, PacBio reads
  • Commet – comparing and combining multiple metagenomic datasets
  • Short Read Connector – connect reads from (meta)-genomic dataset(s)
  • MindTheGap – detection and assembly of DNA insertion variants in NGS read datasets with respect to a reference genome
  • Leon – reference-free read compression
  • Minia – short-read assembler based on a de Bruijn graph
discoSnp++
[page edited on June, 18, 2020] – github webpage Tutorial A toturial can be followed from those slides demo_discosnp Description Software discoSnp++ is designed for discovering Single Nucleotide Polymorphism (SNP) and insertions/deletions (indels) from raw set(s) of reads obtained with Next Generation Sequencers (NGS). Note that number of input read sets is not constrained, it can …
TakeABreak
[last edited on July, 7, 2015] Description TakeABreak is a tool that can detect inversion breakpoints directly from raw NGS reads, without the need of any reference genome and without de novo assembling the genomes. Its implementation has a very limited memory impact allowing its usage on common desktop computers and acceptable runtime (Illumina reads …
Commet
Comparing and combining multiple metagenomic datasets [PAGE Created on July, 29 2014] Description: COMMET (“COmpare Multiple METagenomes”) provides a global similarity overview between all datasets of a large metagenomic project. Directly from non-assembled reads, all against all comparisons are performed through an efficient indexing strategy. Then, results are stored as bit vectors, a compressed representation …
Compareads
Compareads is no more maintained. You can now use the new Commet software which does more and better than compareads. [PAGE UPDATED on July, 29 2014] Description: Compareads is a tool designed to extract similar reads between potentially huge metagenomic datasets (i.e., hundreds of millions reads per dataset) Download: The last Compareads release may be …
Crac
See here: http://crac.gforge.inria.fr/
Gk-Arrays
See here: http://crac.gforge.inria.fr/gkarrays/
Kissplice
See here: http://kissplice.prabi.fr/
MindTheGap
MindTheGap is a tool to detect and assemble insertion variants of any size and any type, by comparison with a reference genome. For download and more details, see the web page : https://gatb.inria.fr/software/mind-the-gap/ Citation Guillaume Rizk, Anaïs Gouin, Rayan Chikhi and Claire Lemaitre. MindTheGap : integrated detection and assembly of short and long insertions. Bioinformatics …
Minia
See here: http://minia.genouest.org/
Mapsembler2
[page edited on August, 24th, 2020] Mapsembler2 is not maintained anymore Sadly, we have no more man power to maintain and to update Mapsembler2.  The last (2014) version is this one:  mapsembler2_2.2.4. Many bug fixes, new features, and optimizations are expected. Any help would be warmly welcome! Mapsembler2 description and possible usages: Mapsembler2 is a …
